Citroen C6 2.2 HDI 2010
floggmolly
Unread post by floggmolly »
I Have A 2010 Citroen C6 2.2 HDI I Drive Into My Driveway And Parked It Up, When I Went Out The Next Day It Wouldn't Start, I Plugged It Into Lexia And Got The Following Fault Codes:
BSI = 1 Fault
F5FF (unexpected re-initialisation fault coming from the BSI) Not Characterised.
Injection / Ignition (EDC16CP39) = 5 Faults
P0113 Air intake temperature signal (air flow sensor). Intermittent, short circuit to Positive,
open circuit or value too high.
P0123 Mixer butterfly position copy signal. Intermittent, short circuit to Positive, open
P0238 Turbo pressure signal (air inlet manifold). Permanent, short circuit to Positive, open
P2100 Motorised throttle control. Intermittent, short circuit between wires.
P2111 Mixer butterfly position copy signal. Permanent, butterfly stuck during post
operation.
Can Anybody Please Help? [-o<
Thank You In Advance :)
vborovic
Locked user account
x 40
Re: Citroen C6 2.2 HDI 2010
Unread post by vborovic »
Wow, that's a lot of errors to get overnight, you sure you didn't feel any changes in the ride in the last few days? Is the battery well charged?
floggmolly
Thanks for the reply, I thought it sounded abit loud since I bought it a few weeks ago?
vborovic
Locked user account
x 40
And you checked for errors with Lexia only once? If so, then we won't know exactly what the situation was right from the start ... maybe to try and do the BSI reset (some members would suggest doing this), just in case some errors are actually not errors, but glitches ... one description of the procedure can be found here (not sure if applicable to your C6):
... if it won't clear at least some of the errors, then your next step should be running tests with Lexia on each of the possible components, to see if it will give you any extra feedback ... after that, well, you go under the hood and beat the hell out of it ... :D ... whatever you do, good luck ...
floggmolly
How do you do the BSI Reset?
x 3298
This is how to do a BSi reset;
It looks complicated, and a common question is "Why?". Think of it as shutting down a PC (as opposed to putting it into standby). If you just pull the power any active files could become corrupted, whereas if you tell Windows to shut down it closes all active files, cleans itself up, and then shuts down cleanly. Well, even when you turn off the ignition and take the key out there are electronics still active (for example, the alarm system), so you need to shut these down as well.
x 2007
Unread post by Stickyfinger »
Tip: do 2nd part, the reconnect part, in the morning after an overnight charge (if you do not have a load tester) to ensure your battery is 100%
x 1499
I would say either the battery has had it; the fuse box has gone dolally; or one of the components that has a 5V control supply has gone belly up and is pulling the voltage down.
Check the battery voltage first...
Jodyone
x 3
Unread post by Jodyone »
If you disconnect the battery on a C6 REMEMBER TO OPEN ALL THE WINDOWS!! At least an inch or so. The windows drop electrically when you open the door, and if you close the door without this having happened- broken window...
Random multiple errors reported on the C6 forum are invariably caused by dead/dying battery, as Richard said. Don't forget the battery's in the boot.
2006 C6 Exclusive, 2.7 HDi - Big Ron. Long gone!!
Trainman
(Donor 2018)
x 43
Unread post by Trainman »
RichardW wrote:I would say either the battery has had it; the fuse box has gone dolally; or one of the components that has a 5V control supply has gone belly up and is pulling the voltage down.
It wouldn't be the first time that a fuse box has failed, although it is more Han likely a battery issue......
Jodyone wrote:If you disconnect the battery on a C6 REMEMBER TO OPEN ALL THE WINDOWS!! At least an inch or so. The windows drop electrically when you open the door, and if you close the door without this having happened- broken window...
good advice about the Windows, a definite must.......If you are unsure where the battery is, then open the boot lid, there is an access panel on the near side, the battery is behind there, NO having said that, it's in a pig of a place, you may well have to remove the boot seal and pull away the side panel to get access.
I know Jodyone has mentioned http://www.c6owners.org" onclick="window.open(this.href);return false; but thought it might be a good idea to give you the address.
If there's anything else, just shout......... oh and welcome to C6 ownership :-D
Steve
http://c6owners.org/index.php
