Just this morning I was hoping to fit the door card and parts back on after fixing the driver side window regulator. I opened the window to adjust the mirror and closed it, as it reached the top I heard a crack and the window fell to the bottom (luckily not smashed, turn out the slider block must have been a crappy reject I ordered it from Turkey, so now I'm waiting for a refund and placing order with UK seller or there's one in Poland.
Just before the car was Mot'd and serviced last week, for some reason I decided to take the MAF sensor apart and clean it with Halfords electrical contact cleaner gave it a good clean, let it dry overnight and fitted it the day of MOT and service, initially on start up it was ok, but I kept stalling a few time and once I got the car back everything seemed ok until I noticed that there was a very very slight delay in the engine responding to speeding up (never happened before I poked around) today I could see more greyish than white smoke from the exhaust 2nd gear 1200 revs and smoke changed to third 20mph and smoke visible from car behind's headlights once up to 30-35ish everything clear.
Still got the track rod ends, bushes on wishbone, lower ball joint, drop links to be fitted both sides and vibration damper.
What am I doing wrong I've treated the car like a newborn, have I damaged the MAF I'm 90% sure it's that (could it be EGR) because everything worked perfectly before I donned the "I know what I'm doing" act, what a tool
Or do I have to take the car for a good run on the motorway to get the newly cleaned MAF sensor working at the new correct rate of air coming in and fuel mix with the ECU.
Cheers
