1.9 xud cam belt change help please :)
taffy
Unread post by taffy »
hi guys hope ur all well long time no see!!
lifes been ok my boys 8 months now and doing good :)
well i was hopeing for some advice as my little 306 is porly :(
went fishing at longleat had a great weekend,on the way back jus getin on m4 and the sound of stones being flicked up happened...the road had no stones :( and suddenly she started to sound like a tractor!:( got back to swindon (limping) and popped the hood....oooh wheres my aux belt gone??? well thought the tractor noise was because of electrical so tested everything and all was good :) :(...done some research and read it might have jumped a tooth...ive locked her up and found yes it was seaminly 1 on cam and 2 on pump....so (long winded i do appologise!) i basically need some tips for refiting a new belt (can do a hdi aint done a xud)
thanks in advance guys its very much appreaciated :)
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
x 8420
Re: 1.9 xud cam belt change help please :)
Taffy,
This thread may help a little. Disregard the title. It is more about belts than pumps...
http://www.frenchcarforum.co.uk/forum/v ... =3&t=49606" onclick="window.open(this.href);return false;
taffy
thats very helpfull thanks jim...wish i had a haynes thou :(
x 3296
Just a thought (but not certain), if you have a Haynes manual for a Xantia, wouldn't it help (as it may cover the 1.9 XUD in said Xantia)?
x 8420
Hell Razor5543 wrote:Just a thought (but not certain), if you have a Haynes manual for a Xantia, wouldn't it help (as it may cover the 1.9 XUD in said Xantia)?
Yes indeed James, good thinking :-D The Xantia manual covers it very well indeed..
taffy
well blow me down!!! i got xantia ones coming out my ears!! good shout guys!!!! :)
x 3296
taffy wrote:well blow me down!!! i got xantia ones coming out my ears!! good shout guys!!!! :)
I hoped you had!
taffy
yes ive got it!:)
taffy
one quick question thou...the pump sprocket i have 2 m8s in but still a little play...would you turn it clockwise or ant1 while fiting the belt,same sort of prinsible as 3 bolts on cam of hdi..?
thanks guys :)
x 8420
Taffy, there should be no play in her pump sprocket at all when locked with M8 bolts. That may bear investigation and may have some bearing on the original slippage.
How much play exactly?
taffy
im jus bein fussy its nex to nothing cam is tight think its the bolt style
BX
x 19
Unread post by BX »
There usually is a tiny bit but just a fraction of one tooth. The important thing is to crank the engine two turns BY HAND softer fitting the belt. This is to ensure nothing is hitting and make sure that even if you are out a tooth no damage will occur when you start the engine
taffy
ah sound thanks mate :)
x 8420
BX wrote:The important thing is to crank the engine two turns BY HAND softer fitting the belt. This is to ensure nothing is hitting and make sure that even if you are out a tooth no damage will occur when you start the engine
Absolutely yes, this task is critical when doing any cambelt...
Fail to do this at your peril...
Thanks for bringing it to all of our attentions BX!
taffy
amount of times i done i t on my hdi u would have thought i was trying 2 start it lmao! at least it was only a rocker and not a valve! :)
