what is this ?
froggy
- (Donor 2026)
- x 4
what is this ?
Hi, my S1 Xantia, built into the windscreen scuttle is a lock that fits the ignition key. What is the purpose of the lock ? probably a silly question. it sits right hand side of the scuttle
Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
- x 94
Re: what is this ?
it to switch/disable/enable the alarm on and off,
i believe it have directional arrows for on and off on its suround
Regards, malcolm.
froggy
- (Donor 2026)
- x 4
Re: what is this ?
around that area ...there is a sound like " long wave radio trying to tune in ! " I guess the alarm must be faulty, cheers Terry.
Terry
Mandrake
- x 695
Re: what is this ?
The siren on my S1 alarm doesn't work (the indicators do flash if the alarm is set off) and I've been trying to work out where the siren disable keylock is as I know it exists somewhere but I don't have an owners manual.
I don't remember seeing anything near the scuttle that looks like a key hole ? Does anyone have a picture of where it is ?
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
- x 8412
Re: what is this ?
The disable key is only on the early S1 models. Up until about 1996.
I don't know the answer for a later S1 either Simon....
- x 94
Re: what is this ?
Simon if your car did have the disable switch/key lock, it will be fitted in the edge of the plastic screen scuttle, were it meets the top edge of bulkhead, and towards the N/S,
uf it were there you cant miss it it looks like the end on view of the ignition lock key hole
Regards, malcolm.
Onlinemyglaren
- x 5672
Re: what is this ?
When I first saw mine I thought it may be the clutch master cylinder
Soon worked out what it was for though.
