2009 C5 suspension pump failure
pentoman
Unread post by pentoman »
Hello,
I have a 2009 C5 Exclusive. It recently had the 'suspension fault' warning. The dealer tells me it's blowing the fuse for the pump although the wiring is okay. So it needs a new pump. This is £1200 fitted.
Has anyone any other sources or suggestions for pumps? Are the refurbished ones any good or how about ebay or a breakers?
qprdude
x 14
Re: 2009 C5 suspension pump failure
Unread post by qprdude »
Take it he means the 40 amp maxi fuse under the engine compartment fuse box?
£1200 fitted?? Can't see it. Even with a new pump that seems OTT.
It has been done before of course. There is a lot of too-ing and Fro-ing on the thread but the bottom line is, a forum member has done it. See here:-
http://www.frenchcarforum.co.uk/forum/v ... =3&t=27078" onclick="window.open(this.href);return false;
Rick.
2013 Citroen DS 5 D/Sport
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Might be worth asking the dealer to check on recalls, prior to purchasing my present one it apparently had a new pump fitted due to a recall.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
