quick HDI question
orinoco74
quick HDI question
So it seems that one of my injectors has failed, I had a diagnostic laptop on it that came from a dealers, 3 of the injectors had almost identical values on-screen but the injector I would call number 2 (second from the left) had a much different value. It wasn't coming up with an error code as apparently its a mechanical error not an electric one. My question is, 2nd from the left, is that cylinder number 2? I have been told because of the way the engine is designed, the cylinders were counted from right to left, making the faulty one on cylinder number 3 (2nd from left, 3rd from right), is this correct?
- x 1055
Re: quick HDI question
Cylinder number one is at the gearbox end of the engine so the one furthest to the right when you open the bonnet.
