Activa struggling to start
Northern_Mike
Remove, clean and remake all the connections to the starter, and do the same for the battery leads at both ends. If that doesn't work then worry about the starter.
Sent from my SM-N9005 using Tapatalk
x 8350
Re: Activa struggling to start
Double post removed Mike...
I'll be interested to hear where she's split herself...
What you need to do with the starter motor Mike is measure the voltage across the battery direct and then at the starter motor itself when cranking to rule out wiring... So often it's the battery clamps at fault where they're crimped onto the cables.
The starter motor is a fun job on an Activa...
x 8350
It differs in that it's a bit of a PITA to swap Mike. I fancy you need to have to big pipe off the throttle body and partially remove the oil filling pot to make space to tease the motor out...
x 1485
Leak is probably the PAS pipe - that's exactly what my HDi did. Which probably means it's knacker's yard time, as the pipe is NFP, and a complete ball ache to change. There are repair possibilities, eg Plaeides, or this one: http://www.frenchcarforum.co.uk/forum/v ... =7&t=49073" onclick="window.open(this.href);return false;
DHallworth
x 166
Unread post by DHallworth »
Mike, is this your red Activa that's burst a pipe? I'm still keen to offer to rehome her if you get to the stage of scrapping her.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
Sl4yer
Unread post by Sl4yer »
Hi.
Is the PAS pipe not available from someone on here now? Or is that a different pipe?
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
DHallworth
x 166
They look like a brilliant investment Mike! Hopefully they'll let you get a proper look under them to see what's going on.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
Xantidote
x 5
Unread post by Xantidote »
Do the ramps have some sort of mechanical interlock, so they stay up as the hydraulics pressure drops (as it will given time). If not, then I'd defo be using a couple of axle stands
Martin
1995 Xantia TDLX (deceased :( )
x 8350
Mike, they look absolutely fantastic and a very good investment :-D
Mandrake
x 695
Unread post by Mandrake »
I think I've just seen my Christmas present! :-D
I need another set of ramps anyway as my machine mart ones aren't very high nor that sturdy - those would be absolutely perfect for raising the car within the confines of a single garage. :) In theory two sets could be used as a poor mans hoist to get both ends in the air a good amount at once, jobs like handbrake cables and exhaust would be so much easier... =D>
If you don't mind me asking Mike, how much were they and where can they be found ?
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 8350
Mandrake wrote:I think I've just seen my Christmas present! :-D
And mine too :-D
I am going to treat myself to a set of those. Just the job for levelling an Activa too...
x 8350
superloopy wrote:What's the do's and donts??
Hold on tight! :lol:
Northern_Mike
Re: Re: Activa struggling to start
Do get someone else to do it.
Don't try yourself.
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
And mine too :-D
I'd have thought anything but those ramps for that job Jim, they have the variable factor built into them as you have separate hydraulic rams whereas traditional ramps can be compared/measured and won't really vary under load.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 8350
DickieG wrote:
And mine too :-D
Good thinking Richard :wink:
There's enough variables in an Activa as it is :twisted: :rofl2:
