Xantia foglamp odity (s2)
Timmo
(Donor 2022)
x 168
Unread post by Timmo »
So, today was chosen as they day to Battle with S'Faf! first and easy job was meant to be swap bulbs in front fogs as they stopped working, they did work, then they didnt, but a tap of the lens made them work again! :shock: :?: :? got my self a pair of new bulbs just incase, set about popping the headlamps out etc. to get to them,
swapped first bulb over and checked them, Nothing,
Swapped second bulb, Nothing,
took bulbs out and checked them, all fine,
checked headlamp connectors incase they were linked, all good,
checked fuse, all good, changed it anyways, Nothing,
checked the voltage at the fuse, just under 12v,
Checked voltage at the foglamp 0.01v!
now, i think that may be part the issue??? but without wanting to pull the whole front end off and look i gave up and set about the rear abs sensor! ;-)
Am i correct in thinking that there should be 12v or close too at the foglamp??
am i going to have to pull the bumper off and investigate the looms??
Any idea's / hints or tips on this would be gratefully received, i use the fogs more for lanes lighting up the edges than anything else, although i have just put some yellow film over them to go for the original look!! ;-) (and also a bit of protection over stone chips, )
Timmo.
'58 C2 Code
'58 partner teepee outdoor
x 3296
Re: Xantia foglamp odity (s2)
I believe that somebody had a similar problem, and found it was a wiring issue in the loom that runs behind the front bumper. I cannot remember more than that.
x 1489
http://www.frenchcarforum.co.uk/forum/v ... =3&t=43236" onclick="window.open(this.href);return false;
Although I think it turned out to be a problem with the headlamp washer pump - which I doubt yours has. Might be the fuse though...
Timmo
(Donor 2022)
x 168
Yes, I have no headlamp washer, just fogs that don't work! Haha! Had a read through thjat and it says 2 fuses for the front fogs? I checked F6 in the engine bay, (can also hear the relay click) but which is the other??
'58 C2 Code
x 3296
Fuse 18 in the cab. 10A (according to handbook X2-GB-4001).
x 8406
I have exactly the same problem on my Activa. Not yet looked in detail but I fear it's the loom...
Timmo
(Donor 2022)
x 168
Thanks guys, will check it in the morning,
If the bumper has to come off to check the loom then so be it, will save that job for when I don't need it for a couple of days! ;-)
'58 C2 Code
x 3296
How was fuse 18 in the cab?
Timmo
(Donor 2022)
x 168
don't know yet! ;-)
'58 C2 Code
Timmo
(Donor 2022)
x 168
a quick glance at the manual to find the location of the incab ones, is the rear fogs fuse, the rears do work as checked that yesterday, so looks more likely that its a loom issue, Bumm!!
'58 C2 Code
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Check your froglamp relay is pulling in - it's one of the green or yellow ones in a row of three relays, in the engine bay box.
Timmo
(Donor 2022)
x 168
will do Addo, i did push them all in when i had the cover off for the fog lamp fuse the other day, but will make sure its in, pretty sure could hear it clicking in when you turn the switch, but will make sure,
'58 C2 Code
addo
x 95
Pull it right out, turn on the fogs, plug back in and you will feel the contacts draw closed if it's working.
Timmo
(Donor 2022)
x 168
Finally got around to having a good poke about on this today,
Passenger side light and indicator out to allow access to the loom , first job was check the loom direct from the battery, all good, checked voltage and 0, so poked around and pulled out the other loom runs from the area, one is the indicator which i had forgotten I'd taken out :rollseyes: the one that was connected and another that had been floating around gathering dirt, so, looking at them, one was grey (indicator), one was grey ouside and purple inside - was connected the other was purple in and out and had been floating around,
So the end of the loom for the lamps was purple, matching the end floating around in the bumper, plugged them together and Bingo! Fog lamps a working! Checked on sidelights, normal lights, full beemers, rear fogs on wuth the others and all seems to be okay, so kinda wondering why was connected to the other plug?? - would that be the loom for lamp washers??
But seems is all good now, thanks for the help again guys, massively appreciate it!
'58 C2 Code
x 8406
Timmo, delighted you found the problem :-D I fixed mine too. Same connector different problem. I had some corrosion on it...
There's always spare connectors knocking round under the bumper. I found all the cruise control wiring on mine although it is unused. Also, you'll find the wiring for headlamp washers even if they're not fitted...
many parts of the loom are common to all models, especially on an S2...
