Probably condensate from the air conditioning. Pretty sure my Activa and old V6 used to drip in the same place when the AC was on. The Berlingo certainly does.
Sent from my SM-N9005 using Tapatalk
Drip, drip, drip
- x 8362
Re: Drip, drip, drip
Yes, that's the condensate drain area...
Also, if not that either your header tank or the bubble-breaker underneath it has a small split in it and it's driopping a little coolant.
Easy way to tell. If it dries away very quickly it';s condensate or if it's coolant it'll take ages to dry and will feel sticky to the touch. It'll also taste very bitter or very sweet.
Condensate will be neither sticky nor tasty!
Mandrake
- x 695
Nor safe to taste, unless you fancy a dose of legionnaires.CitroJim wrote:Condensate will be neither sticky nor tasty!
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
- x 8362
That explains a lot about me thenMandrake wrote:Nor safe to taste, unless you fancy a dose of legionnaires.CitroJim wrote:Condensate will be neither sticky nor tasty!
Mandrake
- x 695
Re:
I'm sure you'll be fine. Just don't make a habit of it!superloopy wrote:Gulp!
Any air con evaporator (and heater matrix) must surely be a fertile breeding ground for bacteria though...
Simon
1978 CX 2400
1978 CX 2400
- x 1450
Legionella requires warm water to thrive, it is typically found in building A/C systems where water is sprayed onto the condenser to improve heat transfer, the heat in the water is dissipated through evaporative loss. Not the scenario found in vehicle A/C systems.
Mandrake
- x 695
Never spoil a good story with facts...xantia_v6 wrote:Legionella requires warm water to thrive, it is typically found in building A/C systems where water is sprayed onto the condenser to improve heat transfer, the heat in the water is dissipated through evaporative loss. Not the scenario found in vehicle A/C systems.
Simon
1978 CX 2400
1978 CX 2400
- x 8362
Says one of the most factual members of this forumMandrake wrote:Never spoil a good story with facts...xantia_v6 wrote:Legionella requires warm water to thrive, it is typically found in building A/C systems where water is sprayed onto the condenser to improve heat transfer, the heat in the water is dissipated through evaporative loss. Not the scenario found in vehicle A/C systems.![]()
