What Xantia and C5 parts are interchangeable?
c.morewood
x 55
Unread post by c.morewood »
Carrying on from Xantos's Engine head thread.
Just what Parts are interchangeable between the Xantia, S2 in my case and the C5?
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
VertVega
x 13
Re: What Xantia and C5 parts are interchangeable?
Unread post by VertVega »
Unfortunately there are almost no parts that are interchangeable.
My comparison is based on these cars: I used to have
Xantia MK2 2.0i 16V (RFV engine) and current C5 MK2 2.0i 16V (RFJ engine).
From Xantia I was able to use H1 head bulbs, brake lights bulbs. I use(d) same type of oil in both cars where engine oil is 5W40 and transmission oil is 75W80. Same battery (dimensions and capacity) can be used in both cars. That was almost the complete list :)
All filters (air, pollen, oil and no fuel filter in C5) are different.
C5 has bigger tires/spare tire with higher speed and load factors.
No LHM but LDS.
My clone Lexia which worked perfect with Xantia doesn't want to co-operate with C5.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
The ONLY things that carried over from experiance is - urm the 2.0 8v HDI engine! and - THATS IT!
Just about everything else is New/Different, even the strut tops went into a further development.. weither it was an improvment or not remains to be seen in about 10 years time when they are getting on for 20 years. Now, weither a C5 Top and strut will work on a Xantia hub and body mounting remains to be seen..
So... the true answer is.... VERY Little.
A very sad...
1994 XM 2.1 d auto
triumphtoledo
Unread post by triumphtoledo »
Bottom ball joints are the same...
R
SaabC5
Unread post by SaabC5 »
Dust caps are interchangeable. :wink:
daviemck2006
x 496
Unread post by daviemck2006 »
They both run on diesel....
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
VertVega
x 13
SaabC5 wrote:Dust caps are interchangeable. :wink:
Good one :wink:
Xantippa
x 29
Unread post by Xantippa »
Rims.
dnsey
x 19
Unread post by dnsey »
Some discs and pads, depending on size.
Not sure about calipers - the seals might be different because of the different fluids.
