Carrying on from Xantos's Engine head thread.
Just what Parts are interchangeable between the Xantia, S2 in my case and the C5?
What Xantia and C5 parts are interchangeable?
c.morewood
- x 55
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
VertVega
- x 13
Re: What Xantia and C5 parts are interchangeable?
Unfortunately there are almost no parts that are interchangeable.
My comparison is based on these cars: I used to have
Xantia MK2 2.0i 16V (RFV engine) and current C5 MK2 2.0i 16V (RFJ engine).
From Xantia I was able to use H1 head bulbs, brake lights bulbs. I use(d) same type of oil in both cars where engine oil is 5W40 and transmission oil is 75W80. Same battery (dimensions and capacity) can be used in both cars. That was almost the complete list
All filters (air, pollen, oil and no fuel filter in C5) are different.
C5 has bigger tires/spare tire with higher speed and load factors.
No LHM but LDS.
My clone Lexia which worked perfect with Xantia doesn't want to co-operate with C5.
No LHM but LDS.
citroenxm
- Fallen Hero
- x 70
The ONLY things that carried over from experiance is - urm the 2.0 8v HDI engine! and - THATS IT!
Just about everything else is New/Different, even the strut tops went into a further development.. weither it was an improvment or not remains to be seen in about 10 years time when they are getting on for 20 years. Now, weither a C5 Top and strut will work on a Xantia hub and body mounting remains to be seen..
So... the true answer is.... VERY Little.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
triumphtoledo
Bottom ball joints are the same...
R
R
SaabC5
Dust caps are interchangeable.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
daviemck2006
- x 485
VertVega
- x 13
SaabC5 wrote:Dust caps are interchangeable.
Good one
Xantippa
- x 29
dnsey
- x 19
Some discs and pads, depending on size.
Not sure about calipers - the seals might be different because of the different fluids.
