Hi, can someone let me know where this valve can be found on the car please?
cheers
Xantia AC expansion valve location
CGATCX25GTITURBO
- x 16
Neil aka CGAT
1986 CX25 GTI TURBO 1 SERIES 2 'CGAT'
1998 XANTIA 19TD ESTATE
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1989 CX GTI Turbo 62k miles in a barn since 2001, project started 2023.
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
Dommo
- x 20
Re: Xantia AC expansion valve location
Behind and below the LHM tank IIRC
CGATCX25GTITURBO
- x 16
thank you
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
citroenxm
- Fallen Hero
- x 70
Expansion valve? Is there another name for it? I cant think of any air con stuff except the connection to the evaporator inside the car in that area...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
CGATCX25GTITURBO
- x 16
TX valve?
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
- x 3306
Neil, you might want to check your avatar. There was an issue that happened when a server change occurred in that some avatars got lost (as well as ROFL2!).
Xaccers
- x 188
Jim's got them, he just hasn't had the time to sort them out. Patience is a virtueHell Razor5543 wrote:Neil, you might want to check your avatar. There was an issue that happened when a server change occurred in that some avatars got lost (as well as ROFL2!).
DIY sphere tool
DIY sphere tool
DickieG
- Monaco's youngest playboy
- x 38
Expansion valve, TX valve, it's the rectangular block that contains the valve which regulates pressure in the evaporator onto which it's mounted.
A quick explanation of its function can be replicated by exhaling with a wide open mouth = warms air, now pucker your lips to a small hole and then exhale = cold air
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
CGATCX25GTITURBO
- x 16
I thought mine might have a problem, took it to kwikfit for a check up, the compressor was kicking just not at all cold. They told me it was leaking from somewhere, no signs anywhere, I took it to Brit tyres in Hull, no leaks found, did a full service on it including the a/c bomb inside the car.. £50, all operating normally now
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
Xaccers
- x 188
That reminds me of a Chinese fable where on a winter's night a traveller takes refuge in I think a giant's home. He blows on his hands to warm them up then blows on a bowl of soup to cool it down. Being scared by this guest being able to breath hot and cold, the giant believes him to be a demon and kicks him out.DickieG wrote:
DIY sphere tool
DIY sphere tool
