Citroen c2 won't start and lights and wipers are going crazy
Lukefergusonc2
Unread post by Lukefergusonc2 »
Hi I was just wondering if anyone could help me I started my c2 the other night and my horn stopped working plus my indercators and headlights won't go off same with the wipers iv checked all the fuses there isn't no problem there my storks don't work either then when I try to start my car a day later it will not start can someone help PLEASE :( it's not a fuse problem thanks :( my wipers come on when put ignition on and non of the storks work :/
x 1052
Re: Citroen c2 won't start and lights and wipers are going c
Unread post by wheeler »
Sidelights & wipers coming on when not asked to means the BSI has lost communication with the Com2000 unit. My first thoughts on this are a faulty Com2000 (lighting & wiper stalk)
Lukefergusonc2
But would that cause the car not to start I'm so confused :(
x 1052
Lukefergusonc2 wrote:But would that cause the car not to start I'm so confused :(
Yes it can cause a non start situation, the receiver for the immobiliser goes through this unit.
Lukefergusonc2
Ok no problem helped a lot if I buy a new identical com2000 will it have to be programed :/
Northern_Mike
Comm2000 units don't need to be programmed. They are not cheap though! There's a chap called Graeme up in Bradford who repairs them, but I can't find his number! Have a look see on berlingoforum.co.uk, hes on there somewhere.
Enviado desde mi GT-I9505 usando Tapatalk
Lukefergusonc2
Ok mate thanks ever so much I'll take them out now and let you now the out come it's been flustering me all day it all makes sence now my air bag light is on aswell see so it's looking good I hope fingers crossed
demag
x 102
Unread post by demag »
Be careful with the airbag mechanism when you disconnect everything.
Dave
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Check your fuses first. Usually one feeds the COMM unit, failure of the fuse will cause everything you describe.
x 94
Re:
Unread post by citronut »
addo wrote:Check your fuses first. Usually one feeds the COMM unit, failure of the fuse will cause everything you describe.
Adam
the OP says "its not a fuse",
but maybe there are hidden maxi fuses under the main engine bay fuse box, so if the OP dud not know of this possibility there could maybe still be a fuse poped
also Luke ??
check here
http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178" onclick="window.open(this.href);return false;
for a LEXIA owner in your area
Regards, malcolm.
addo
x 95
On the grey COMM unit plug, check Pin 4 for earth and Pin 5 for battery voltage with ignition on.
x 1052
If your car has ESP the steering angle sensor in the com2000 will need to be programmed with Lexia, if not then its plug & play.
And yes best to confirm power supplies & earth before jumping in & replacing the unit, the problems described can also be a short or open circuit in the data wires between the com2000 & the under bonnet fusebox.
