C5 2.0L snapped cambelt, likely damage.
handyman
Unread post by handyman »
I've been offered a C5, 2.0i petrol engined, with a snapped cambelt. Its a very low mileage, long MOT & quite tidy, so might be a worthy proposition if internal damage is not too bad. What is the likely damage to be? Bent valves, snapped cam caps, snapped camshafts?
I know what happens on the earlier TU engines, but not on these later DW lumps.
Handyman
addo
Sara Watson's Stalker
x 95
Unread post by addo »
16 new valves, I'd check the pistons all came up to the same deck height and dust a little talc on the crowns after decarbonising.
x 1240
Re: C5 2.0L snapped cambelt, likely damage.
Unread post by Peter.N. »
Don't know about petrol engines but on the 8 valve diesel it only usually breaks the rockers, not even a head off job.
x 1056
Unread post by wheeler »
A 2.0 petrol will be an EW engine not a DW, do you know if it's an HPi or not ? I would avoid an HPi like the plague even without a snapped timing belt.
Either way 99% chance of valve damage, cams & carriers normally ok.
Timmo
(Donor 2022)
x 168
Unread post by Timmo »
When the belt went on my 16v bx I was lucky to get away with valves only, was a 50mph gentle acceleration from a 40 when it went,
You may get away with a head swap if your lucky??
'58 C2 Code
'58 partner teepee outdoor
handyman
Thanks for the info, chaps. =D> Gone off the idea now, given the costs involved, as I was only going to buy it, sort it out & sell it on. [-X [-X 8-[
H
x 1240
Pick a diesel one they are much easier - but only the 2.0. 8 valve.
SwissSPEC
Unread post by SwissSPEC »
Petrol C5's are completely worthless, so i'd save the effort as you'll be unlikely to find a buyer even at £500. The diesels are cheap anyway, so there's little demand for the petrol one's, which means if you were going to fix it to keep, then its a lot of car for little money.
CX GTI 2 Turbo (LHD) - Sorn
Bx Gti 16v
BX TZD Turbo - Sorn
C5 Mk1 LX 2.0HDi Estate
Mini Cooper D Clubman
falling-out-with-my-car
x 25
Unread post by falling-out-with-my-car »
handyman,
PM sent
