I've been offered a C5, 2.0i petrol engined, with a snapped cambelt. Its a very low mileage, long MOT & quite tidy, so might be a worthy proposition if internal damage is not too bad. What is the likely damage to be? Bent valves, snapped cam caps, snapped camshafts?
I know what happens on the earlier TU engines, but not on these later DW lumps.
Handyman
C5 2.0L snapped cambelt, likely damage.
addo
- Sara Watson's Stalker
- x 95
- x 1240
Re: C5 2.0L snapped cambelt, likely damage.
Don't know about petrol engines but on the 8 valve diesel it only usually breaks the rockers, not even a head off job.
- x 1056
A 2.0 petrol will be an EW engine not a DW, do you know if it's an HPi or not ? I would avoid an HPi like the plague even without a snapped timing belt.
Either way 99% chance of valve damage, cams & carriers normally ok.
Timmo
- x 168
When the belt went on my 16v bx I was lucky to get away with valves only, was a 50mph gentle acceleration from a 40 when it went,
You may get away with a head swap if your lucky??
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
handyman
Thanks for the info, chaps.
Gone off the idea now, given the costs involved, as I was only going to buy it, sort it out & sell it on.
H
H
- x 1240
Pick a diesel one they are much easier - but only the 2.0. 8 valve.
SwissSPEC
Petrol C5's are completely worthless, so i'd save the effort as you'll be unlikely to find a buyer even at £500. The diesels are cheap anyway, so there's little demand for the petrol one's, which means if you were going to fix it to keep, then its a lot of car for little money.
CX GTI 2 Turbo (LHD) - Sorn
Bx Gti 16v
BX TZD Turbo - Sorn
C5 Mk1 LX 2.0HDi Estate
Mini Cooper D Clubman
Bx Gti 16v
BX TZD Turbo - Sorn
falling-out-with-my-car
- x 25
handyman,
PM sent
PM sent
