Fusebox Xantia 1996
mikep
Fusebox Xantia 1996
Unread post by mikep »
Need to change a fuse on my Xantia, the fusebox is located beneath steeriing coloumn and has a red lever.
I have tried pulling on the red lever but nothing gets released. Can anyone confirm the red lever
should open the fusebox ? I don't want to force it.
mikep
Citroen Xantia auto sx 1996
x 1492
Re: Fusebox Xantia 1996
The red lever is the bonnet release....
The fuse box is to the right of the steering column, there's a turn buckle just above knee height that releases it.
mikep
Thanks for that, I use the bonnet release regularly but did not know it was red !
I will find the turn buckle and let you know.
mikep
mikep
Found it ! how could I miss it. difficult to read though..
mikep
