Lexia Key Coding
jgra1
(Donor 2021)
x 36
Lexia Key Coding
Unread post by jgra1 »
chaps, about to take the plunge and try and code a key to my C5..
can someone point to a post that describes this, or even just tell me where to start within Lexia? I am guessing coding is not within diagnostic menu?
thanks
John
Ben82
x 7
Re: Lexia Key Coding
Unread post by Ben82 »
You mean like this? :)
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
jgra1
(Donor 2021)
x 36
perfect, thanks Ben ;)
the new key I have does have buttons for RCL.. I am guessing these wont work until after the car and key have met each other?
Ben82
x 7
there's a separate process for the RCL, which lexia does give you information at the same time for pairing.
jgra1
(Donor 2021)
x 36
right.. will take my wine outside and try it ;)
jgra1
(Donor 2021)
x 36
worked fine.. easy!
but the RCL doesn't.. which is the main reason I brought a new key (with buttons)
hmm
x 3299
I don't know if this will work, but it is worth a try. On an S2 Xantia what you do is to pop the new key in the ignition, turn on the ignition, and then press a remote button. That should then sync the remote function to the car.
jgra1
(Donor 2021)
x 36
yep James.. tried it, for a 10 second press..(as per lexia instructions) nothing,. a bit later took key apart and rotated battery and tried again.. no go..
is there an easy way to see if key is emitting?
KP
x 27
Unread post by KP »
Its RF so afraid not :(
x 3299
Only if you have RF equipment on the right frequency. Are you sure the battery is good? Just because the key is new doesn't mean the battery is. It could be 'old new' stock, whereby the key had been sitting on the shelf for a few years. According to Wikipedia the keys operate on 433.92 MHz.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
On the BSI parameters there should be a line something like "presence of RF signal" from memory.
jgra1
(Donor 2021)
x 36
thanks addo..
tried a new battery but nothing,,
a minor update.. haven't been near the key for a week or two.. but spoke to IT guy here, and he produced his Digital £40 HAM radio.. we typed in 433.925 ? I think,.. and sure enough, on a press of any of the 3 buttons, there was a noticeable 'crack' in the signal.... I cant be sure that it's emmiting the right signal, but it's certainly doing something..
Will go back to Lex later and have a look around.. but is it possible to turn on / off RCL with it? could someone have disabled it , in the past
John
x 3299
The fact that the ham radio gets a response suggests the keyfob is working. I wonder if the in-car receiver is?
