Relay van 2000 clutch problem
fridgedoc
Unread post by fridgedoc »
Hi Guys
Clutch pedal dropped to floor with a "snapping" sound, managed to coax it home, found a piece of broken black plastic on floor of van, trying to remove the cable so I can see the end of the cable that fits to the clutch pedal but cannot work out how it comes apart, any help please
Many thanks
Stephen
I did do a search and could only find one post but the link to a diagram does not work :(
Bonne Chance
Stephen
LHD Xantia 1994 (deceased)
LHD Xantia 1995 Berline
x 3296
Re: Relay van 2000 clutch problem
If it is like that on a Xantia, the black clip (which was of a poor, weak design) has been replaced with a cream clip that has a better design. The clip (and spring clip) were still available 18 months ago.
The following link might be of help, but it is for a Xantia, not a Relay;
http://www.frenchcarforum.co.uk/forum/v ... e&start=15" onclick="window.open(this.href);return false;
fridgedoc
Thanks for your reply Hell razor it's similar but not the same as the relay
Bonne Chance
Stephen
