Steering rack issue!
KennyW
x 164
Unread post by KennyW »
Hi All,
The power steering rack has developed the following problem when you turn either right or left about half a turn on steering wheel, there is a distinct increase of resistance but after you go past this problem disappears until you return to the same point.
Is this the power steering ram showing signs of wear :?:
Kenny
C3 1.4 petrol (SWMBO)
rory_perrett
Re: Steering rack issue!
Unread post by rory_perrett »
Is your UJ well greased/lubricated?
As it is when you turn both left and right I wouldn't suspect the ram as it would be in two different positions depending on whether you are turning one way or the other.
KennyW
x 164
Rory,
After posting gave UJ a spray with plusgas and problem solved. Will lubricate it with Lithum grease soon.
Kenny
rory_perrett
Kenny
That's great news - we love the quick easy fixes. I use spray grease that turns up in the 99p/£1 shops occasionally.
Rory
