Hello guys,
My citroen xantia 98 reg is running hot, around 90 to 100 c° while driving..
I have changed the coolant temp sensor, the tstat & bled the cooling system so far..
Anybody have any ideas?
Xantia II running hot
Xaccers
- x 188
Re: Xantia II running hot
Are the radiator fans actually running?
DIY sphere tool
DIY sphere tool
djadams
- x 14
Conceivably, could be the water pump impellor spinning on the shaft... That'd give you reduced coolant flow and hence higher coolant temperatures. Difficult to check without removing it though, so as they're not expensive it may be time for some swapagnostics.
2000 Xantia Activa 2.0 TCT (Danowned Activa
daily driver)
1968 DS21 Pallas BVH (high days and holidays)
kilianmanning
Yup, the fan kicks inXac wrote:Are the radiator fans actually running?
kilianmanning
Right I see, have a full t belt kit there ready for it, hasn't been changed for a long timedjadams wrote:Conceivably, could be the water pump impellor spinning on the shaft... That'd give you reduced coolant flow and hence higher coolant temperatures. Difficult to check without removing it though, so as they're not expensive it may be time for some swapagnostics.
- x 1240
If its done a high mileage could be the radiator is clogged.
Estately
- x 22
Or following Peter's theme, could be rubbish caught between the air con condenser and the radiator which would reduce the air flow.
Andy
Andy
If it can happen it will.
