Xantia II running hot
kilianmanning
Unread post by kilianmanning »
Hello guys,
My citroen xantia 98 reg is running hot, around 90 to 100 c° while driving..
I have changed the coolant temp sensor, the tstat & bled the cooling system so far..
Anybody have any ideas?
Xaccers
x 185
Re: Xantia II running hot
Unread post by Xaccers »
Are the radiator fans actually running?
DIY sphere tool
djadams
x 14
Unread post by djadams »
Conceivably, could be the water pump impellor spinning on the shaft... That'd give you reduced coolant flow and hence higher coolant temperatures. Difficult to check without removing it though, so as they're not expensive it may be time for some swapagnostics.
2000 Xantia Activa 2.0 TCT (Danowned Activa :D daily driver)
1968 DS21 Pallas BVH (high days and holidays)
kilianmanning
Xac wrote:Are the radiator fans actually running?
Yup, the fan kicks in
kilianmanning
djadams wrote:Conceivably, could be the water pump impellor spinning on the shaft... That'd give you reduced coolant flow and hence higher coolant temperatures. Difficult to check without removing it though, so as they're not expensive it may be time for some swapagnostics.
Right I see, have a full t belt kit there ready for it, hasn't been changed for a long time
x 1238
Unread post by Peter.N. »
If its done a high mileage could be the radiator is clogged.
Estately
x 22
Unread post by Estately »
Or following Peter's theme, could be rubbish caught between the air con condenser and the radiator which would reduce the air flow.
Andy
If it can happen it will.
