peugeot 306 wipers
dispatch
peugeot 306 wipers
Unread post by dispatch »
i am looking for help with my peugeot 306 xsi
i recently bought it and found that the wipers do not park
also they do not work on intermitant wipe
if anyone knows how to fix this i would be gratefull if they could tell me how .[8D]
x 1055
Unread post by wheeler »
its more than likely a faulty timer relay.
dispatch
thanks for the help i had a feeling it was something to do with that
i dont suppose you know where it is located?
im guessing its in the fuse box somewhere.<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by wheeler</i>
Ben83
Unread post by Ben83 »
dispatch,
I had a similar problem earlier this year, which disappeared on its own. I did get some advice here, although I never got to the bottom of the problem. These two threads might be worth a read:
http://www.andyspares.com/discussionfor ... IC_ID=2618 and http://www.andyspares.com/discussionfor ... IC_ID=2883
Please let me know if you find a solution, so I've got something else to try if mine ever comes back!
Cheers,
Ben.
1995 306 1.4.
dispatch
im still having problems locating the relay
i think im going to get the help of the dealership
IanS
Unread post by IanS »
The relay for the wipers is the blue one behind the trim pannel below the steering wheel (where the fuses are). Replace the relay and this should rectify your problem - it did for me!
Ian
tacker
Unread post by tacker »
same thing just happened to me but mine is a 306 van dont have any blue relays any ideas
dispatch
i dont have any blue relays either
jackherer
Unread post by jackherer »
turn the wipers on and see if you can hear/feel which relay is clicking.
kevin
Unread post by kevin »
On the 309/205 and my 306 there is a black 6 pin relay in the box
tacker
opened up the motor there are 3 pins inside the connecter plate cleaned it and adjusted the pins works sound now
shawn
Unread post by shawn »
On other older cars that I have had the self park switch is built into the wiper motor.
How would a relay know where the wiper arm was on the screen.MMMmmm??
dispatch
this wiper thing is doing my swede in
i will spend some more time on it next weekend
bezbow
Unread post by bezbow »
My 306 rear wiper has a mind of its own. Only works when it wants
to! Often when off!!
Russell
Unread post by Russell »
I haven't looked at the 306 circuit schematic but when my Porsche 924 intermittent wiper relay died (it went intermittent-intermittent), it was possible to remove the relay and jumper the relay socket with a short length of wire with a couple of spade connectors to restore the self park. That's been working for the last 15 years OK [:-)]
I bet the controls are likely to be very similar.
Cheers
Russell
