wishbone bushes
froggy
(Donor 2026)
x 4
wishbone bushes
Unread post by froggy »
Hi, is it best to source your wishbone bushes from main dealer ? rather than "motor factor" ? will main dealer bushes last longer ? thanks in advance Terry. :?:
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
x 1987
Re: wishbone bushes
Unread post by Stickyfinger »
froggy wrote:Hi, is it best to source your wishbone bushes from main dealer ? rather than "motor factor" ? will main dealer bushes last longer ? thanks in advance Terry. :?:
You cannot beat a bit of "Quality Bush"
sparksie
x 33
Re: wishbone bushes
Unread post by sparksie »
I think the biggest factor affecting bush longevity is going to be how close you can get them to their correct positions.
This is no easy task and I had to give up with mine slightly wrong on both sides of the car.
Try to go for a quality brand, made to OE spec. I used QH and FEBI and was pleased with both!
Sparksie
2000 Xantia 1.9TurboD
isisalar
x 3
Re: wishbone bushes
Unread post by isisalar »
There's lots of pattern ones out there for about £20 e@ or less, quality unknown, Genuine ones are about £35 from Citroen. The genuine ones may well have alignment marks on. As Sparksie has said, the alignment is critical, any bush wont last long if it's positioned badly.
Cheers
Paul
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
