wishbone bushes
froggy
- (Donor 2026)
- x 4
wishbone bushes
Hi, is it best to source your wishbone bushes from main dealer ? rather than "motor factor" ? will main dealer bushes last longer ? thanks in advance Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
- x 1987
Re: wishbone bushes
You cannot beat a bit of "Quality Bush"froggy wrote:Hi, is it best to source your wishbone bushes from main dealer ? rather than "motor factor" ? will main dealer bushes last longer ? thanks in advance Terry.
sparksie
- x 33
Re: wishbone bushes
I think the biggest factor affecting bush longevity is going to be how close you can get them to their correct positions.
This is no easy task and I had to give up with mine slightly wrong on both sides of the car.
Try to go for a quality brand, made to OE spec. I used QH and FEBI and was pleased with both!
Sparksie
2000 Xantia 1.9TurboD
isisalar
- x 3
Re: wishbone bushes
There's lots of pattern ones out there for about £20 e@ or less, quality unknown, Genuine ones are about £35 from Citroen. The genuine ones may well have alignment marks on. As Sparksie has said, the alignment is critical, any bush wont last long if it's positioned badly.
Cheers
Paul
Cheers
Paul
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
