Rain sensor Xantia 2.0Hdi Exclusive
Edhertz
x 5
Unread post by Edhertz »
Can someone tell me how to remove the rain sensor cover? Windscreen is damaged and needs to be replaced,
Cheers in advance
Alan
1999 Xantia Exclusive 2.0Hdi Mauritius blue
1999 Peugeot LX 1.9D silver
Chris570
x 36
Re: Rain sensor Xantia 2.0Hdi Exclusive
Unread post by Chris570 »
it slides either up or down, i forget which, the mirror goes with it.
Make sure you recover the clear gel pad things
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
xf1ref
x 12
Unread post by xf1ref »
The mirror case slide down , after you remove it you will see the rain sensor. To remove the sensor from the windscreen you have to pull the two green clips from sides.
Edhertz
x 5
Thanks for your replies folks. Easy when you know how!
Alan
Edhertz
x 5
Good to belong to this forum!
Alan
