Hi,
Can someone tell me how to remove the rain sensor cover? Windscreen is damaged and needs to be replaced,
Cheers in advance
Rain sensor Xantia 2.0Hdi Exclusive
Edhertz
- x 4
Alan
1999 Xantia Exclusive 2.0Hdi Mauritius blue
1999 Peugeot LX 1.9D silver
Chris570
- x 36
Re: Rain sensor Xantia 2.0Hdi Exclusive
it slides either up or down, i forget which, the mirror goes with it.
Make sure you recover the clear gel pad things
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
xf1ref
- x 11
The mirror case slide down , after you remove it you will see the rain sensor. To remove the sensor from the windscreen you have to pull the two green clips from sides.
Edhertz
- x 4
Thanks for your replies folks. Easy when you know how!
Alan
Edhertz
- x 4
Good to belong to this forum!
Alan
