MoT today
x 2000
MoT today
Unread post by Stickyfinger »
and just clicked past 160K.....................
Fail, CV gaiter................turned out to be mud !
Fail, Side Lights..............one blub blown...the bugger was working on Sunday
Fail, ABS wires "not in clip".......all I can say is to rude to post without a life bad....
Smoke @ 0.45 average....my cat and DPF work then :)
New serpentine belt fitted.....WHAT a mess, I was lucky !
Oil New in ; Engine, GearBox, Steering rack.
Rear Brakes...........ZERO corrosion...well there is a first for everything !"
All in all I would call that a result
Northern_Mike
Re: MoT today
I think the point is that being insecure, something could snag them and rip them out thus rendering your ABS useless. I think it's a fair enough one to fail on.
Northern_Mike
Re: MoT today
Probably the latter. Strict testers are a good thing. Jobsworth ones are not.
x 2000
Re: MoT today
................. he took more time identifying a smear of wet mud as a split and leaking gaiter than moving a loose wire 4cm into a clip :)
Northern_Mike
Re: MoT today
Mine took me under the ramp and said "it's just scraping a pass so far because some of these pipes are furry and I had to try for ages to get the emissions down, but <taps rotten pipe> I really can't pass that I'm afraid. <taps rust on subframe> See, that's rusty but it's all there and it's solid. That pipe is not. Helpful explanation, honest, not a jobsworth. I know a few who'd have failed it on some of the other pipes that are sound.
John Plum
x 5
Re: MoT today
Unread post by John Plum »
Sounds like we like testers too, to be reasonable and helpful like the whole world.
Sent from a mobile transmitter.
John Plum
Xantia II Estate,1999, 2.0 HDI LX, 17000 miles, manual
