Hi all, I've been chasing a rattle for a while that turned up suddenly. I have new drop links, rod ends, ball joints in the last year so I suspected the wishbone bushes but there's no movement in any. I then got underneath and found movement in the steering rack. It looked like the whole thing was loose at first then realized it was the passenger side track rod moving and moving the pas ram with it.
I'm sure this is the cause of the rattling now. But why is it moving here? It feels like the rack itself is loose not the inner track rod joint. I'm guessing there's bearings the rack moves on that are worn out but how to change them and can they even be sourced?
I recall my old gsa had a similar problem that turned out to be a spring loaded plunger in the steering rack that was sticking and the solution was to heat it up from the outside whereby it popped back out against the inner rack. I can't see anything similar on the xantia though. Any ideas?
xantia front end rattle again
aerodynamica
- x 215
Graeme M
taffy
Re: xantia front end rattle again
maybe check the steering rack uj?
if u lookunder driver side arch u can see it aswell as down the back left side of engine..get some one to rock the steering and keep ur eye on it..as i recall it did rattle
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
aerodynamica
- x 215
Cheers, trouble is I can see the slackness at the other end of the rack so it's definitely at the passenger side.
Graeme M
taffy
ah right...im sure someone will know mate
aerodynamica
- x 215
Thanks taffy! I love xantias but mine is really showing its age (20)
Graeme M
taffy
me too!
yeah they are getting aged now but i would prefer one to a new car...i always modernise my cars..nice lights gadgets etc
makes it feel alot newer!
aerodynamica
- x 215
Well it looks like it stops rattling when you're braking
Graeme M
taffy
Caliper spring missing
aerodynamica
- x 215
There is one missing! But I could see movement at the steering on one side
Graeme M
taffy
the caliper will just flop about without it
aerodynamica
- x 215
Anyone have a caliper spring?
Graeme M
addo
- Sara Watson's Stalker
- x 95
