can we use c5 front suspension sphere on xantia front suspension, anyone who used to use it?
How about the feeling? and how it effect for along time.
Can we.....?
- x 1240
Re: Can we.....?
I would certainly try it, you will need the correct type - hydractive or not. The only other possible problem is that the C5 type is slightly larger in diameter, its also a different shape so you really need a proper tool.
aneesh84
- x 29
Re: Can we.....?
I believe it could be successful.The long life of a c5 sphere is a big advantage. I believe it can last about 10 years.
I know of someone who used c5 spheres in the xantia and was happy with the results. If you do experiment please let us know.
Xantia Estate 1999 2.0 HDI 110
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
C5 2005 2.0 HDI 138
Northern_Mike
Re: Can we.....?
I'm sure I've seen Xantias with the grey UFO spheres from a C5 on.
fox01
Re: Can we.....?
One thing that worries me is hydraulic fluid, as it's not the same, lhm may be effect to diaphragm in side the sphere or not.
My xantia isn't a hydractive 3 sphere in front and 3 sphere on the rear
aneesh84
- x 29
Re: Can we.....?
from the only guy who did this that i know of, it wasnt a problem.
C5 2005 2.0 HDI 138
C5 2005 2.0 HDI 138
