Can we.....?
fox01
Can we.....?
Unread post by fox01 »
can we use c5 front suspension sphere on xantia front suspension, anyone who used to use it?
How about the feeling? and how it effect for along time.
x 1240
Re: Can we.....?
Unread post by Peter.N. »
I would certainly try it, you will need the correct type - hydractive or not. The only other possible problem is that the C5 type is slightly larger in diameter, its also a different shape so you really need a proper tool.
aneesh84
x 29
Re: Can we.....?
Unread post by aneesh84 »
I believe it could be successful.The long life of a c5 sphere is a big advantage. I believe it can last about 10 years.
I know of someone who used c5 spheres in the xantia and was happy with the results. If you do experiment please let us know.
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
Northern_Mike
Re: Can we.....?
I'm sure I've seen Xantias with the grey UFO spheres from a C5 on.
fox01
Re: Can we.....?
One thing that worries me is hydraulic fluid, as it's not the same, lhm may be effect to diaphragm in side the sphere or not.
My xantia isn't a hydractive 3 sphere in front and 3 sphere on the rear
aneesh84
x 29
Re: Can we.....?
from the only guy who did this that i know of, it wasnt a problem.
C5 2005 2.0 HDI 138
