Do these all use the same rockers as Xantia HDi models (or was there any sort of change)? Got to order in a set for someone.
Thanks, Adam.
Just Quickly - Early C5 8V Diesel
addo
- Sara Watson's Stalker
- x 95
OnlineRichardW
- x 1485
Re: Just Quickly - Early C5 8V Diesel
Appears to be, part no 0903 64, also comes back against:
1 document(s) found for XSARA II
1 document(s) found for C5
1 document(s) found for XANTIA II
1 document(s) found for BERLINGO (M59)
1 document(s) found for C4
1 document(s) found for RELAY
1 document(s) found for DISPATCH I & II
1 document(s) found for XSARA PICASSO
1 document(s) found for SYNERGIE
2 document(s) found for RELAY II
addo
- x 95
OnlineRichardW
- x 1485
citroenxm
- Fallen Hero
- x 70
Valves will (or at least should) be perfectly fine... I repeaird one that broke a belt at 55 mph.. NO valve bend, just 6 rocker fingers... with bearing fitted to them.
Would of sold you a set of 8 for 30 quid adam..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
addo
- x 95
