Just Quickly - Early C5 8V Diesel
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Do these all use the same rockers as Xantia HDi models (or was there any sort of change)? Got to order in a set for someone.
Thanks, Adam.
x 1492
Re: Just Quickly - Early C5 8V Diesel
Appears to be, part no 0903 64, also comes back against:
1 document(s) found for XSARA II
1 document(s) found for C5
1 document(s) found for XANTIA II
1 document(s) found for BERLINGO (M59)
1 document(s) found for C4
1 document(s) found for RELAY
1 document(s) found for DISPATCH I & II
1 document(s) found for XSARA PICASSO
1 document(s) found for SYNERGIE
2 document(s) found for RELAY II
addo
x 95
Ta; just plopped £90 on a set plus two spares. Local chap forgot to unpin his cam after doing the belt, belt stripped and mistimed the valves.
x 1492
Ouch, bet that rather spoiled his day #-o
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Valves will (or at least should) be perfectly fine... I repeaird one that broke a belt at 55 mph.. NO valve bend, just 6 rocker fingers... with bearing fitted to them.
Would of sold you a set of 8 for 30 quid adam.. :wink:
A very sad...
1994 XM 2.1 d auto
addo
x 95
I'm not really involved in the job other than supplying some parts as a barter. Genuine rockers here are $120 EACH.
If I offered secondhand ones, they'd try to bargain me down. :x
