Problem with rear suspension
KennyW
x 164
Unread post by KennyW »
Afternoon All,
I've just fitted a new rear bracket between anti roll bar and HCas a result of a broken link, suspension dropped (see previous thread).
I cannot get the rear suspension to rise and fall at all. What's happened :?:
I need to fit new sphere's to rear (3)
Kenny
C3 1.4 petrol (SWMBO)
KennyW
x 164
Re: Problem with rear suspension
Had time to think and my next question is, Has the height corrector seized.
I'm going to remove same and give it a good clean.
Kenny
electronmirror
x 31
Unread post by electronmirror »
Will it rise and fall using the manual adjustment lever near the handbrake?
If it will, then quite possible the new clamp is nowhere near the right position on the anti roll bar. It can be a fiddle to get it in roughly the right place to start with.
Always a good idea to clean the linkage mechanism off the car, it can be removed without disconnecting hydraulic pipes on the height corrector.
Good luck :)
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (133,509miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
KennyW
x 164
Quick update, the HC was seized and with some lubrication and judicial use of an adjuster I have got it to move.
Next the spheres, I think I will leave these until next weekend when I can get access to a hydraulic ramp.
Kenny
