Correct Aux belt size?
c4tobe
Hello folks,
I am ordering a new aux belt (V-Ribbed Belt) online.
What is the right aux belt for Citroen C4 hatch, 1.4 Petrol, 88hp, year 2004, with A/C ?
For my car, I found these:
Number of ribs: 6.
Length: 1050, 1070, 1125, 1145 (mm) ? which one?
Number of ribs: 6.
- x 94
Re: Correct Aux belt size?
if you send me the last 8 digits of your chassis/VIN No. i will check on service citroen for you
Regards, malcolm.
aneesh84
- x 29
Can you please check my belt size also. My VIN No. is VF7**************[VIN obfuscated, can be read by forum staff]
Cant seem to find it.
Xantia Estate 1999 2.0 HDI 110
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
C5 2005 2.0 HDI 138
- x 1493
Aneesh,
Even service.citroen doesn't know! It depends on what AC compressor is fitted. 1736 if it's a Sanden, 1750 if it's a Delphi.
aneesh84
- x 29
Ahhh…. I will try to go under the car to check that! thank you for your help.
C5 2005 2.0 HDI 138
C5 2005 2.0 HDI 138
SaabC5
Is the belt so badly worn you can't read the length on the belt? ie 6PK 1736
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
aneesh84
- x 29
Actually the belt is not that worn. Just I should try to get the belt to stop where I can read, and i tried starting, stopping the engine a couple of times and couldnt get it.
The car is 15 years old, and driven 114000 miles. Do you think I should worry about changing the belt for preventive maintenance? it doesnt squeal or make any sound.
C5 2005 2.0 HDI 138
C5 2005 2.0 HDI 138
Stewart(oily)
- x 35
Put the car in second gear (handbrake off) and nudge it backwards using your knees
watch the belt go by.
Mandrake
- x 695
I wouldn't recommend turning the engine backwards by pushing it backwards in 2nd gear. Not good for the valves...Stewart(oily) wrote:Put the car in second gear (handbrake off) and nudge it backwards using your kneeswatch the belt go by.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
- x 94
cant you just make sure your local motor factors has both belts in stock, so when you remove the old one ypu know you can access the correct one
Regards, malcolm.
Stewart(oily)
- x 35
It only moves a few degrees each nudge, easy to see the valvegear when doing clearances, never had a problem.Mandrake wrote:I wouldn't recommend turning the engine backwards by pushing it backwards in 2nd gear. Not good for the valves...Stewart(oily) wrote:Put the car in second gear (handbrake off) and nudge it backwards using your kneeswatch the belt go by.
aneesh84
- x 29
I finally managed to read the length on the aux belt. It was some alphabets followed by 1755!
The citroen website only showed 2 options 1738 and 1750. So confused!
C5 2005 2.0 HDI 138
C5 2005 2.0 HDI 138
VertVega
- x 13
Then the correct length should be 1750.aneesh84 wrote:I finally managed to read the length on the aux belt. It was some alphabets followed by 1755!
I found two codes,
- Gates 6PK 1753 ......... length 1750 mm
- Continental 6PK 1750 ... length 1750 mm
Mark the direction on the old belt before removing it.
In case you have to re-install it you should fit it so that it's same direction.
Measure the old and new belt by stretching together. Belt tensioner can fix
some mm changes
- x 1493
The HDi has a manual eccentric tensioner as well, so you may well need to adjust that to get the new belt on / get the auto tensioner in the right place.
Thought...if the aux belt hasn't been replaced at 114k, has the cambelt....????
aneesh84
- x 29
Yes I recently got the cambelt replaced. Thats when the mechanic told me that I could get the aux belt replaced next service, though not that urgent.
C5 2005 2.0 HDI 138
C5 2005 2.0 HDI 138
