LHM leak on the return... any "y" connectors handy?
moosemaster
Hello one and all, I wonder if anyone can help me source a wee part?
Noticed a pool of LHM collecting under the front of my Xantia, took it into a garage and popped it on the ramp. There's a "y" shaped junction under the subframe that appears to be leaking, the mechanic reckons it's gone hard and brittle over the years and needs to be replaced. Does anybody know where I can procure such a thing, anyone got one handy? If anybody's had the same problem before and there's a quick fix I'd love to know.
Many thanks
Sean
Many thanks
Sean
Stewart(oily)
- x 35
Re: LHM leak on the return... any "y" connectors handy?
I have repaired return pipework using plastic push on connectors and fuel line suitable for diesel, I got the connectors on ebay and the line from my local factors.
VertVega
- x 13
Does it look like this? I have posted this long time ago for another member's leak case.
Since they are return pipes they are easier than the supply lines. As you can see those
pipes are "pop-in" type.
moosemaster
Thanks for the reply, that's good to know, would you be able to point me in the direction of the connectors you used? I've found some brass ones, not sure if they'd be suitable...Stewart(oily) wrote:I have repaired return pipework using plastic push on connectors and fuel line suitable for diesel, I got the connectors on ebay and the line from my local factors.
VertVega wrote:Does it look like this? I have posted this long time ago for another member's leak case.
The pipes pop into the connector but it looks different to what you've posted - I found this picture whilst trawling old posts trying to find a name for the bit I'm after; I'm after the connector the arrow on the left is pointing to...
VertVega
- x 13
You mean the ones over the rear sub frame
The one I sent was in front sub frame, under LHM tank, close to steering pinion valve.
Any way the idea is same, pop in type and return line with no high pressure issues.
You can easily find them from scrap yards and they are almost with no value for the owner.
Edit: Here's pic from a scrap car. As far as I remember Y-link material is not metal but plastic/rubber as in my above pic's 4-way connector. This one would be the one on the right side in your pic
Both left and right are same.
citroenxm
- Fallen Hero
- x 70
Ive often knocked the offending item off the return stub at the front, just under the steering rack.
Ive got a car on the trailer to goto scrap, that had no leaks, unfortunally I wont be at the farm again till wednesday, but can have a look then and see if I can get it off it for you...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
moosemaster
Oooh, I'm still getting to grips with automobile terminology...VertVega wrote:You mean the ones over the rear sub frameThe one I sent was in front sub frame, under LHM tank, close to steering pinion valve.
Edit: Here's pic from a scrap car. As far as I remember Y-link material is not metal but plastic/rubber as in my above pic's 4-way connector. This one would be the one on the right side in your picBoth left and right are same.
When swapping it over I take it it's just a matter of being as quick as possible?
- x 94
if its the three way union in the last picy above here is price and part No. from citroen ( cough cough )
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
5451210 RET TUBE SLEEVE 12.65 GBP 15.18 GBP 15.18 GBP
one of the plastic pipes going to this union comes from the safety valve
theres no problem disconnecting these union as they dont have any pressure in them,
as they are just seepage/capillary returns
Regards, malcolm.
VertVega
- x 13
Is it possible to send a pic of Y-connector? You can be sure that you'll get the item code and price here
In front and under there are not many Y-connectors. I guess it might even be the one in my first pic.
Since it has been cleaned, it might not look same as the one under the car which has collected
all the mud and oil for more than a decade.
Stewart(oily)
- x 35
Heres a link to what I have used, I think 6mm was the size, someone correct me if I`m wrong.
you will need rubber fuel hose to effect a repair too.
http://www.ebay.co.uk/itm/Y-Piece-NYLON ... 25786eaf5a" onclick="window.open(this.href);return false;
moosemaster
That would be great, ta! Messaged a few folk on Ebay who are breaking Xantias and have been in touch with my local Citroen garage to see if they can get me the part. Will be in touch if none of my enquires are fruitful..citroenxm wrote:Ive often knocked the offending item off the return stub at the front, just under the steering rack.
Lovely, looks like the right part - a google came up with a picture of the same piececitronut wrote:if its the three way union in the last picy above here is price and part No. from citroen ( cough cough )
I think we're in business...
Ah great, I shall give this a shot if a replacement spongle doesn't work, thank you very muchStewart(oily) wrote:Heres a link to what I have used, I think 6mm was the size, someone correct me if I`m wrong.
Thanks for your help folks!
- x 94
it not worth fitting a second hand one of these, as once they have been pulled apart there is more chance of them not holding together for long
Regards, malcolm.
moosemaster
Very good point. Managed to get one ordered through my Citroen garage for a fiver, problem solved. Thanks for the help and advice everyone, you shall be rewarded in heavencitronut wrote:it not worth fitting a second hand one of these, as once they have been pulled apart there is more chance of them not holding together for long
aneesh84
- x 29
Hi VertVega,VertVega wrote:Does it look like this? I have posted this long time ago for another member's leak case.
Exactly this part has cracked and LHM is leaking in my car. Can you please help me with the part number?
Xantia Estate 1999 2.0 HDI 110
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
C5 2005 2.0 HDI 138
aneesh84
- x 29
This is the picture of the leaking part from my car.
C5 2005 2.0 HDI 138
C5 2005 2.0 HDI 138
