If you have a Lexia and the 4 digit code can you code keys
xsaras4ever
x 44
Unread post by xsaras4ever »
Hello ,
On a Xsara (Phase 1), if you do a complete engine swap or injection pump change, then your ignition key will show an error and you pump will not work.
If you have a Lexia and the 4 digit code specific to your car (from Citroen), then can you re-code your pump or ignition key ?
We ask this because we don't have a Lexia and want to be sure it can be done before we buy one.
Its a DW8 engine, old engine has a Lucas pump and the new one has a Bosch.
Thank You
Jumper 2.5d
406 Phase 2 Estate, Hdi
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
Fordson Major Tractor
Nuffield 460 tractor
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
citroenxm
Fallen Hero
x 70
Re: If you have a Lexia and the 4 digit code can you code ke
Unread post by citroenxm »
Swap the pump and injectors!!!
Its NOT hard, and far cheaper then buying a lexia. OK The bosch pump is more durable but for the sake of buying a Lexia I wouldn;t Id swap pumps...
REMEBER THIS THOUGH: If you do swap pumps, when you get the pump off the back plate, SWAP all three Pump locating dowls to the opposite of the three holes!!! You'll see what I mean when you get the pump off!!!
SWAP injectors too!!!
A very sad...
1994 XM 2.1 d auto
citroenxm
Fallen Hero
x 70
To answer your original question, YES is the answer!!
A very sad...
1994 XM 2.1 d auto
xsaras4ever
x 44
Thanks you for both replies.
Swapping pumps is an option for us.
However, we are tempted to finally buy a Lexia. We have 4 Xsaras in the family and a Peugeot 406.
All diesel, all pre-2002 .
We have a spare Desktop PC in the garage - Windows XP , Pentium 4 - will a Lexia run happily with that ?
Also , does this look like a good buy ?
http://www.ebay.co.uk/itm/Lexia-3-Diagn ... 43bf3c11d1
Thank again
Jumper 2.5d
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
citroenxm
Fallen Hero
x 70
Its ok, but anything earlyer then 1998 needs the 30 pin connector plug, which doesnt; seem to be in this kit..
That PC sounds like it should be surfice to run Lexia/PP2000
A very sad...
1994 XM 2.1 d auto
