Hello ,
On a Xsara (Phase 1), if you do a complete engine swap or injection pump change, then your ignition key will show an error and you pump will not work.
If you have a Lexia and the 4 digit code specific to your car (from Citroen), then can you re-code your pump or ignition key ?
We ask this because we don't have a Lexia and want to be sure it can be done before we buy one.
Its a DW8 engine, old engine has a Lucas pump and the new one has a Bosch.
Thank You
If you have a Lexia and the 4 digit code can you code keys
- x 39
Jumper 2.5d
406 Phase 2 Estate, Hdi
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
Fordson Major Tractor
Nuffield 460 tractor
JCB 3cx
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
- x 71
Re: If you have a Lexia and the 4 digit code can you code ke
Swap the pump and injectors!!!
Its NOT hard, and far cheaper then buying a lexia. OK The bosch pump is more durable but for the sake of buying a Lexia I wouldn;t Id swap pumps...
REMEBER THIS THOUGH: If you do swap pumps, when you get the pump off the back plate, SWAP all three Pump locating dowls to the opposite of the three holes!!! You'll see what I mean when you get the pump off!!!
SWAP injectors too!!!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 71
To answer your original question, YES is the answer!!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 39
Thanks you for both replies.
Swapping pumps is an option for us.
However, we are tempted to finally buy a Lexia. We have 4 Xsaras in the family and a Peugeot 406.
All diesel, all pre-2002 .
We have a spare Desktop PC in the garage - Windows XP , Pentium 4 - will a Lexia run happily with that ?
Also , does this look like a good buy ?
http://www.ebay.co.uk/itm/Lexia-3-Diagn ... 43bf3c11d1
Thank again
Thank again
Jumper 2.5d
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
- x 71
Its ok, but anything earlyer then 1998 needs the 30 pin connector plug, which doesnt; seem to be in this kit..
That PC sounds like it should be surfice to run Lexia/PP2000
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
