Got a headlamp bulb blown on the C5
Napoleon
- x 4
And posting this thread is the first thing I have done to get the ball rolling towards getting it fixed.
It's the sort of thing I want to do myself. Anyone got any pointers to suppliers please, and also to fitting one?
It's the left hand headlamp that's u/s.
Cheers in advance.
Cheers in advance.
Tim
2009 HV09 C5 2.2
1996 N679 Xantia TD VSX estate - sold August 2012
1995 M289 Xantia TD SX hatch - sold March 2012
Tarte au Citroen
2009 24" iMac 3.06GHZ
2009 HV09 C5 2.2
Tarte au Citroen
VertVega
- x 13
Re: Got a headlamp bulb blown on the C5
Another BUMPER OFF JOB ...
That's the typical advice but so far I managed to replace headlight bulbs 3 times without removing the bumper
Napoleon
- x 4
Bumper OFF?!!!
Tim
2009 HV09 C5 2.2
Tarte au Citroen
2009 HV09 C5 2.2
Tarte au Citroen
- x 1996
welcome to modern carsNapoleon wrote:Bumper OFF?!!!
or...as above....blue tac is your friend ...as is a three fingered squid
Xantidote
- x 4
Don't you wish now that you'd not got rid of the xantia??Napoleon wrote:Bumper OFF?!!!
Martin
1995 Xantia TDLX (deceased
vborovic
- Locked user account
- x 40
If your C5's the newest model ('09 or later), and in case you don't have Xenon's, I can assure you each lightbulb for both headlamp units can be easily replaced, without taking the bumper off or other extreme measures ... the only activity you have to do before is remove the rubber lids on the back off the headlamps ...
... although, smaller hands would come in handy ...
Napoleon
- x 4
Ha ha!Xantidote wrote:Don't you wish now that you'd not got rid of the xantia??Napoleon wrote:Bumper OFF?!!!
Tim
2009 HV09 C5 2.2
Tarte au Citroen
2009 HV09 C5 2.2
Tarte au Citroen
- x 94
easy option
get ride of the C5 and buy a dersh ( 2CV )
even i can change a head light bulb on the dersh without removing the back bumper
Regards, malcolm.
Napoleon
- x 4
Saw your comments on a thread on this subject from 2006!
Anyway, best advice might be to buy the bulb from Halfords and let them do the job - is the fitting for free at Halfords or do they charge for the pleasure? I'm sure a regular garage would charge the earth.
Tim
2009 HV09 C5 2.2
Tarte au Citroen
2009 HV09 C5 2.2
Tarte au Citroen
- x 1996
We have established that Halfords do not "do" the C5 Facelift or later models...they have a list
Napoleon
- x 4
No such thing as a free lunch, eh? Typical.
Tim
2009 HV09 C5 2.2
Tarte au Citroen
2009 HV09 C5 2.2
Tarte au Citroen
- x 94
om sure young!! Stevey baby ( mygleran ) will be along soon pointing you in the direction of the thread were i warn persons to steer well clear of Hal_frauds for this procedure
:missile: :missile:
maybe this subject should be placed in the supper stickies section
Regards, malcolm.
qprdude
- x 14
Yes, Halfords charge £6+ to fit a bulb, but they don't do the C5, (or any car that you couldn't do yourself in 5 minutes)
Be careful of advice on removing the bumper etc. The X7 is a different beast, and too much advice is from guys with earlier cars with totally different procedures. Not sure if there is a difinitive procedure on the forum for changing a headlight bulb on the X7, but certainly there was advice to remove the bumper to change DRL and side lights which was subsequently proved to be wrong by one owner.
Rick.
2013 Citroen DS 5 D/Sport
vborovic
- x 40
Hopefully I'll be the second one to prove that for the DRLs ...qprdude wrote:but certainly there was advice to remove the bumper to change DRL and side lights which was subsequently proved to be wrong by one owner.
- x 94
and when they tried on a face lift model they pulled the bulb retaining wore clip clean of the back of the head lamp, the owner told them to get away from his car befopre they did more damage,qprdude wrote:Yes, Halfords charge £6+ to fit a bulb, but they don't do the C5,
the side lights are the ones which run all the way along the top of the head lamp, on the face lift version at least
Regards, malcolm.
