Got a headlamp bulb blown on the C5
Napoleon
x 4
Unread post by Napoleon »
And posting this thread is the first thing I have done to get the ball rolling towards getting it fixed.
It's the sort of thing I want to do myself. Anyone got any pointers to suppliers please, and also to fitting one?
It's the left hand headlamp that's u/s.
Cheers in advance.
Tim
2009 HV09 C5 2.2
1996 N679 Xantia TD VSX estate - sold August 2012
1995 M289 Xantia TD SX hatch - sold March 2012
Tarte au Citroen
2009 24" iMac 3.06GHZ
VertVega
x 13
Re: Got a headlamp bulb blown on the C5
Unread post by VertVega »
Another BUMPER OFF JOB ...
That's the typical advice but so far I managed to replace headlight bulbs 3 times without removing the bumper 8-)
Napoleon
x 4
Bumper OFF?!!!
Tim
2009 HV09 C5 2.2
Tarte au Citroen
x 2004
Unread post by Stickyfinger »
Napoleon wrote:Bumper OFF?!!!
welcome to modern cars :)
or...as above....blue tac is your friend ...as is a three fingered squid
Xantidote
x 4
Unread post by Xantidote »
Don't you wish now that you'd not got rid of the xantia?? :)
Martin
vborovic
Locked user account
x 40
Unread post by vborovic »
If your C5's the newest model ('09 or later), and in case you don't have Xenon's, I can assure you each lightbulb for both headlamp units can be easily replaced, without taking the bumper off or other extreme measures ... the only activity you have to do before is remove the rubber lids on the back off the headlamps ... :) ... although, smaller hands would come in handy ...
Napoleon
x 4
Ha ha!
Tim
2009 HV09 C5 2.2
Tarte au Citroen
x 94
Unread post by citronut »
easy option
get ride of the C5 and buy a dersh ( 2CV )
even i can change a head light bulb on the dersh without removing the back bumper :yikes: :rofl2: :-D :wink:
Regards, malcolm.
Napoleon
x 4
Saw your comments on a thread on this subject from 2006!
Anyway, best advice might be to buy the bulb from Halfords and let them do the job - is the fitting for free at Halfords or do they charge for the pleasure? I'm sure a regular garage would charge the earth.
Tim
2009 HV09 C5 2.2
Tarte au Citroen
x 2004
We have established that Halfords do not "do" the C5 Facelift or later models...they have a list :)
Napoleon
x 4
No such thing as a free lunch, eh? Typical.
Tim
2009 HV09 C5 2.2
Tarte au Citroen
x 94
om sure young!! Stevey baby ( mygleran ) will be along soon pointing you in the direction of the thread were i warn persons to steer well clear of Hal_frauds for this procedure :yikes: :missile: :missile:
maybe this subject should be placed in the supper stickies section
Regards, malcolm.
qprdude
x 14
Unread post by qprdude »
Yes, Halfords charge £6+ to fit a bulb, but they don't do the C5, (or any car that you couldn't do yourself in 5 minutes)
Be careful of advice on removing the bumper etc. The X7 is a different beast, and too much advice is from guys with earlier cars with totally different procedures. Not sure if there is a difinitive procedure on the forum for changing a headlight bulb on the X7, but certainly there was advice to remove the bumper to change DRL and side lights which was subsequently proved to be wrong by one owner.
Rick.
2013 Citroen DS 5 D/Sport
vborovic
Locked user account
x 40
qprdude wrote:but certainly there was advice to remove the bumper to change DRL and side lights which was subsequently proved to be wrong by one owner.
Hopefully I'll be the second one to prove that for the DRLs ... :D ... or die trying ... if by sidelights you mean the ones that light up when you turn the steering wheel in some direction, then I can also say it is possible to replace the bulbs on them, done it myself ...
x 94
qprdude wrote:Yes, Halfords charge £6+ to fit a bulb, but they don't do the C5,
and when they tried on a face lift model they pulled the bulb retaining wore clip clean of the back of the head lamp, the owner told them to get away from his car befopre they did more damage,
the side lights are the ones which run all the way along the top of the head lamp, on the face lift version at least
Regards, malcolm.
