Citroen c5 2002 hdi
Citroen c5 2002 hdi
can anyone give me adv,engine light came on today along with antipollution fault and service light . no very little about cars one of the members suggested
pressure washing the filter can anyone explain to a layman where it is . also the car is not worth spending any big money on it, how long do you reckon i could run it before it packs in
yours robert
yours robert
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
Re: Citroën c5 2002 hdi
Robert, is it a 2.0 or a 2.2
where are you based
that fault comes up often and doesn't always mean anything too serious.. it can mean a lot of different things really..
John
where are you based
John
2lt m8
in n ireland
in n ireland
- (Donor 2021)
MG TF 135
BMW R1200RT
BMW K1300 R
ahh you shouldn't have the FAP filter,,, so that's not the issue..
to be honest my anti pollution fault came on last week.. car went into limp mode.. cleared itself almost straight away..
EGR valve cleaning, EGR relays are possibles,, others will know more,
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
That will be the particle filter they're talking about. It's situated in the exhaust system approximately under the front seats. The exhaust will need to be lowered then the filter box removed and opened. However unless your C5 is fitted with the 2.2 engine, you won't have one. The 2ltr engines didn't get particle filters until late 2004.roberthutchman wrote: pressure washing the filter can anyone explain to a layman where it is .
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4888
Which engine?
If it is the 2L you won't have a particle filter to worry about.
"Antipollution Fault" can mean a lot of things but is rarely applicable to the DPF. The notification is generally "Diesel Filter Blockage" or similar.
Is the car running as well as usual?*
Do you make lots of short trips so it never gets properly warmed through?
After being restarted half a dozen times and driven for at least ten minutes, does the fault still display?
*If so, hammering it down the motorway for fifty miles is often very beneficial.
Here are some threads dealing with similar issues that may provide some clues as to how to proceed:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=33458" onclick="window.open(this.href);return false;
http://www.frenchcarforum.co.uk/forum/v ... hp?t=28713" onclick="window.open(this.href);return false;
http://www.frenchcarforum.co.uk/forum/v ... hp?t=19274" onclick="window.open(this.href);return false;
http://www.frenchcarforum.co.uk/forum/v ... p?p=119290" onclick="window.open(this.href);return false;
This is by no means an exhaustive list but will get you on the right track.
Do come back with any further questions and others will be along before long to add to this.
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
Hells bells, beaten by just about everybody
- (Donor 2021)
MG TF 135
BMW R1200RT
BMW K1300 R
hehhee
normally use it for driving to work approx 10 miles away. today went to belfast lot more traffic 70 miles away thats when the 3 lights came on
robert
robert
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1199
Mine is running permanently with the engine and service light on but as I rarely drive at over 60 mph or 2000 rpm it doesn't bother me in the least, will still do 60 mpg. I did notice though, the other day I had to drive up a long very steep hill after which the lights went out, so I wonder if its just sooted up.
Just passed
got a diagnostic, problem air flow meter, egr valve but told this wont affect the driving of the 2002 models just the later ones. only mot
is the c5 known for head gasket problems.what is the first signs?
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1280
- Contact:
2ltr engine in the C5 is bomb proof.....or should be unless really badly abused. Heads blowing are rare unless water pump goes/water loss/never topped up...but that's why heads go , its not normally the head that is at faultroberthutchman wrote:is the c5 known for head gasket problems.what is the first signs?
MAF sensor WILL effect the driving of the car as it prevents/retards turbo working correctly. Who is telling you these things ??
Activa, the Moose Rider
3x C5x7 Steering racks and counting
