Citroen c5 2002 hdi
roberthutchman
Citroen c5 2002 hdi
Unread post by roberthutchman »
can anyone give me adv,engine light came on today along with antipollution fault and service light . no very little about cars one of the members suggested
pressure washing the filter can anyone explain to a layman where it is . also the car is not worth spending any big money on it, how long do you reckon i could run it before it packs in
yours robert
jgra1
(Donor 2021)
x 36
Re: Citroën c5 2002 hdi
Unread post by jgra1 »
Robert, is it a 2.0 or a 2.2
where are you based
that fault comes up often and doesn't always mean anything too serious.. it can mean a lot of different things really..
John
roberthutchman
2lt m8
in n ireland
jgra1
(Donor 2021)
x 36
ahh you shouldn't have the FAP filter,,, so that's not the issue..
to be honest my anti pollution fault came on last week.. car went into limp mode.. cleared itself almost straight away..
EGR valve cleaning, EGR relays are possibles,, others will know more,
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
roberthutchman wrote: pressure washing the filter can anyone explain to a layman where it is .
That will be the particle filter they're talking about. It's situated in the exhaust system approximately under the front seats. The exhaust will need to be lowered then the filter box removed and opened. However unless your C5 is fitted with the 2.2 engine, you won't have one. The 2ltr engines didn't get particle filters until late 2004.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
x 5670
Which engine?
If it is the 2L you won't have a particle filter to worry about.
"Antipollution Fault" can mean a lot of things but is rarely applicable to the DPF. The notification is generally "Diesel Filter Blockage" or similar.
Is the car running as well as usual?*
Do you make lots of short trips so it never gets properly warmed through?
After being restarted half a dozen times and driven for at least ten minutes, does the fault still display?
*If so, hammering it down the motorway for fifty miles is often very beneficial.
Here are some threads dealing with similar issues that may provide some clues as to how to proceed:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=33458" onclick="window.open(this.href);return false;
http://www.frenchcarforum.co.uk/forum/v ... hp?t=28713" onclick="window.open(this.href);return false;
http://www.frenchcarforum.co.uk/forum/v ... hp?t=19274" onclick="window.open(this.href);return false;
http://www.frenchcarforum.co.uk/forum/v ... p?p=119290" onclick="window.open(this.href);return false;
This is by no means an exhaustive list but will get you on the right track.
Do come back with any further questions and others will be along before long to add to this.
x 5670
Hells bells, beaten by just about everybody :(
jgra1
(Donor 2021)
x 36
hehhee :rofl2:
roberthutchman
normally use it for driving to work approx 10 miles away. today went to belfast lot more traffic 70 miles away thats when the 3 lights came on
robert
x 1240
Unread post by Peter.N. »
Mine is running permanently with the engine and service light on but as I rarely drive at over 60 mph or 2000 rpm it doesn't bother me in the least, will still do 60 mpg. I did notice though, the other day I had to drive up a long very steep hill after which the lights went out, so I wonder if its just sooted up.
x 1485
It will unfortunately bother your MOT man now though Peter.....
x 1240
Just passed 8-)
roberthutchman
got a diagnostic, problem air flow meter, egr valve but told this wont affect the driving of the 2002 models just the later ones. only mot
roberthutchman
is the c5 known for head gasket problems.what is the first signs?
x 1997
Unread post by Stickyfinger »
roberthutchman wrote:is the c5 known for head gasket problems.what is the first signs?
2ltr engine in the C5 is bomb proof.....or should be unless really badly abused. Heads blowing are rare unless water pump goes/water loss/never topped up...but that's why heads go :), its not normally the head that is at fault
MAF sensor WILL effect the driving of the car as it prevents/retards turbo working correctly. Who is telling you these things ??
