Strut
lasthope1967
Strut
if my Strut bearing went would I get knocks from it seems iam getting that noise coming from around them parts iam going to stick new anti roll bar sway bar bushes & links in ,,get no noise on smooth roads,,just when the road is uneven
xsara Picasso hdi 2.0-------- 2003
- x 1240
Re: Strut
Anti roll bar drop links would be my first port of call. I have never heard of a strut bearing going on a Citroen - but I suppose its possible but I don't think it would rattle because its under permanent load.
Chris570
- x 36
Re: Strut
I have seen strut bearings go on AX/106's before, but Peter is right, I think i'd be looking at the bottom of the suspension first
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
Old-Guy
- x 24
Re: Strut
Drop links are a common replacement. Various makes and prices - generally you get what you pay for, cheap ones may last for 10,000 miles on poor roads. Lemforder branded ones have the best reputation for lasting, but are most expensive - the factory original N/S drop link on the Green Lady failed around 75,000, the Lemforder replacement is still sound at 114,000 miles. You pays your money....
Drop link nuts can sometimes be swines to remove - following this technique isn't guaranteed to avoid problems, but it does minimise the risk and does include a safe and relatively easy way to get seized nuts off.
Northern_Mike
Re: Strut
Yes.lasthope1967 wrote:if my Strut bearing went would I get knocks from it seems iam getting that noise coming from around them parts iam going to stick new anti roll bar sway bar bushes & links in ,,get no noise on smooth roads,,just when the road is uneven
The Berlingo rattled like hell when it's strut top mount failed. More of a metallic tap than a knock though. Terrible on roughish roads. Fine over speed bumps.
I've gone through two top mounts on the left side in two years! Still on the same one on the right but I know it was replaced a few years ago.
Sent from my GT-I9300 using Tapatalk 4
