Had a bash at this on the way home from work yesterday as I've had to start using the GS again and it's grumbly-rumbly.
a) I was on the way home and not heavily tooled-up.
b) I haven't done one before, and hadn't read up on it before hand
So with that in mind, got the hub nut undone, removed the two bolts holding the top balljoint in place, removed the two bolts holding the bottom balljoint in place, quick strike with a hammer and split the track rod end taper. Wandered over to the bench with the hub assembly. Spent some time picking the rubber seal out. Then discovered the lock ring. Ahh. Gaahh. Decide not to proceed further to prevent immobilising the car and went home in disgust!
So I understand I need to buy/make a tool out of a huge socket with a bar slotted into it to engage with the two slots in this ring. I also understand that this ring is 'king tight. I also understand that I might need something tapered to push the hub itself out of the inner race. What is the plastic reducer bush all about in the new bearing? Is it surplus to requirements in this application? Do I need anything fancy to get it all back together.
Your thoughts please.... (calling Malcolm!
Cheers,
Rich
