Hi all,
Pardon my ignorance.
Do you know whether Citroen uses hydraulic or electric power steering pump in their C5 II (year 2004 ~ 2008)?
If electric power steering pump is used, does it still rely on the shared reservoir with the suspension system?
Kindly advise me.
Thank you very much.
Regards,
Hydraulic or Electric Power Steering Pump?
- x 1240
Re: Hydraulic or Electric Power Steering Pump?
The Haynes manual very helpfully says that there are two types used, yes you've guessed it - and mechanical or an electric one. If you look at the auxiliary drive belt you should be able to see it if its mechanical.
Clogzz
- x 40
The belt-driven hydraulic pump does the steering.
The electric pump does the suspension.
The LDS tank feeds both pumps.
- x 5634
There's a suggestion that some but not all more recent C5s have an electric steering pump too.Clogzz wrote:The belt-driven hydraulic pump does the steering.
Mandrake
- x 694
Surely looking up the VIN on service.citroen.com will provide the answer ?
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
Clogzz
- x 40
The power steering pump for VIN VF7**************[VIN obfuscated, can be read by forum staff] is electric, and it costs thousands.
The part number is 4007 QH.
Mandrake
- x 694
Chalk up another one for modern technological "advancement"...Clogzz wrote:The power steering pump for VIN VF7**************[VIN obfuscated, can be read by forum staff] is electric, and it costs thousands.![]()
What exactly is the allure of an electric power steering pump ? An electric pump for the suspension I can kind of understand (height corrections when loading a non running car) but you only need steering assistance when the engine is running, so why make it electrical and more prone to fail...(not to mention more expensive apparently)
Simon
1978 CX 2400
1978 CX 2400
- x 1476
It shaves 0.1 MPG off the combined figure, and about the same off the CO2. It probably also saves a few seconds on the build line!
- x 2941
Probably easier to make variable, computer controlled, light when at low speed, parking etc. heavier at high speed for straight line stability.
Chris570
- x 36
and one less thing to bolt to the engine leaving more room for other addons
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
Clogzz
- x 40
It only pumps when you're steering at low speeds, so it needs sensors and other troublesome frills to find out how you're steering.What exactly is the allure of an electric power steering pump ?
The C5's electric suspension pump keeps the car level on the move.
The headlights dim when it switches on, and it also causes the idle speed to drop.
The Xantia doesn't have that problem,
