Hydraulic or Electric Power Steering Pump?
begins
Unread post by begins »
Hi all,
Pardon my ignorance.
Do you know whether Citroen uses hydraulic or electric power steering pump in their C5 II (year 2004 ~ 2008)?
If electric power steering pump is used, does it still rely on the shared reservoir with the suspension system?
Kindly advise me.
Thank you very much.
Regards,
x 1240
Re: Hydraulic or Electric Power Steering Pump?
Unread post by Peter.N. »
The Haynes manual very helpfully says that there are two types used, yes you've guessed it - and mechanical or an electric one. If you look at the auxiliary drive belt you should be able to see it if its mechanical.
Clogzz
x 40
Unread post by Clogzz »
The belt-driven hydraulic pump does the steering.
The electric pump does the suspension.
The LDS tank feeds both pumps.
x 5651
Clogzz wrote:The belt-driven hydraulic pump does the steering.
There's a suggestion that some but not all more recent C5s have an electric steering pump too.
x 694
Unread post by Mandrake »
Surely looking up the VIN on service.citroen.com will provide the answer ? :wink:
Clogzz
x 40
The power steering pump for VIN VF7**************[VIN obfuscated, can be read by forum staff] is electric, and it costs thousands. :evil:
The part number is 4007 QH.
x 694
Clogzz wrote:The power steering pump for VIN VF7**************[VIN obfuscated, can be read by forum staff] is electric, and it costs thousands. :evil:
Chalk up another one for modern technological "advancement"... :roll:
What exactly is the allure of an electric power steering pump ? An electric pump for the suspension I can kind of understand (height corrections when loading a non running car) but you only need steering assistance when the engine is running, so why make it electrical and more prone to fail...(not to mention more expensive apparently)
x 1480
It shaves 0.1 MPG off the combined figure, and about the same off the CO2. It probably also saves a few seconds on the build line!
x 2941
Probably easier to make variable, computer controlled, light when at low speed, parking etc. heavier at high speed for straight line stability.
Chris570
x 36
Unread post by Chris570 »
and one less thing to bolt to the engine leaving more room for other addons
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
Clogzz
x 40
It only pumps when you're steering at low speeds, so it needs sensors and other troublesome frills to find out how you're steering. :evil:
The C5's electric suspension pump keeps the car level on the move.
The headlights dim when it switches on, and it also causes the idle speed to drop. :evil:
The Xantia doesn't have that problem, :evil: the height correctors do the levelling for free.
