HDI HIGH PRESSURE PUMP
Post Reply
beeplumber
My Cars:
Post by beeplumber »
Car would not start last night had to walk home, looked at it tonight fuel to filter, but no fuel to common rail.
so am thinking the pumps knackered. cam is turning so drive belt should be okay. Are their many different
pumps or do all of 2lt HDI pumps fit. it's a 2lt Xantia Exclusive. many thanks for any help. Mik
citroenxm
My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising
x 71
Re: HDI HIGH PRESSURE PUMP
Post by citroenxm »
Hi there.
ALL 8v HDi Pumps are the same NO MATTER if they are a 90bhp or a 110bhp.. and theres NO need for a Lexia to program it either..
Just swap and go!
How did you test the Pump operation? Did you crack open an injector union?
IF you are quite clever too, theres no need to remove the cam timing belt either! I have swapped a pump twice without removing the belt.. I let the pump pully with the belt still round it rest on the lower part of the belt area, removed the pump carefully and refitted. The HDi high pressure pump is NOT timed either! Just plonk it back on and tighten it all up.
A very sad...
1994 XM 2.1 d auto
beeplumber
My Cars:
Hi yes cracked open the unions to injectors then the common rail no fuel at any joints.
citroenxm
x 71
Post by citroenxm »
Its not unknown for the hdi pump on the engine to stop... as i said above any 2.0 8v 90bhp or 110bhp pump will do.
A very sad...
1994 XM 2.1 d auto
Post Reply
