Hi All,
Could someone please tell me the *correct* procedure for bleeding cooling system in a 2.0 HDI 8V in a 2002 C5?
Thanks..
Mike
C5 2.0HDI MK1 Cooling system
citroenxm
- Fallen Hero
- x 70
Re: C5 2.0HDI MK1 Cooling system
Same as the xantia i guess. Run the engine theres a bleeder on the heater matrix out pipe and one on the side of the thermostat house and one on the top of the radiator too.. i run the engine and squeeze the top hose rigeriously.. if that doesnt work ill re fit the bleeders and go quickly up the road and back. The quick hard drive useually shifts any air locksm then ill re open the bleeders and see where we are up to. The heater pipe bleeder should give a fountain when you remove it OR if its flowing both will be warm..
Hdi have laminated gaskets from factory and issues are very rare although peter n still found some. (
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Ben82
- x 7
Official Citroen Doc:
https://mega.co.nz/#!sscyDAhR!dvTXd1L-U ... XBr-7lcgT4" onclick="window.open(this.href);return false;
Hope it helps
Hope it helps
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
Northern_Mike
Cheers Ben, I'll give it a go tomorrow. I'll invest in a new tank and cap first, then I can make a refilling bottle with the old cap and a 2 litre bottle I have.
- x 8406
Northern_Mike
Well, what does it mean when I take the coolant cap off a stone-cold engine (hadn't run for at least 20 hours) and it blows coolant out under considerable pressure?
It's @#$$ ed?
Ran it up to Woodley, 4 miles. Twas nice and hot and bubbling away to itself. I opened the header tank cap again and it bubbled over. I thought "sod it" and just went about my day of 20 miles or so. The fan came on when it should, it didn't "appear" to overheat but I really need Lexia on it to see live coolant temps.
I'm really not hopeful it just needs bleeding.
Sent from my GT-I9300 using Tapatalk 4
It's @#$$ ed?
- x 1996
There is only one place that pressure can come from....but you know that
Northern_Mike
Yeah, caveat emptor and all that, but I've a feeling I've been stitched up here.
