Morning all,
discovered the reason behind the passenger door dropping when opened yesterday, appears that the lower hinge has been hiding some rust form me!! looks like its cracked all around the weld on the visible side and underneath too,
looking at it, is it going to be a case of clean up and reweld or a Plate around it?? as not being a welder myself, i'd like the best options so i know what to clean up and preped and arrange to get it done by my welder chap?? - am aware it'll be a door off job!
many thanks in advance guys,
Timmo.
P2 Xantia Lower door hinge, how best to repair??
- Timmo
- My Cars: 58 partner teepee outdoor hdi.
58 C2 Code in black! Fun! - x 168
- Contact:
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
- My Cars: Xsara SX (2003) Last of the line.
- x 6
Re: P2 Xantia Lower door hinge, how best to repair??
I bet it's an estate.
Have a look in How-To Section. http://www.frenchcarforum.co.uk/forum/v ... 22&t=31218" onclick="window.open(this.href);return false;
- Timmo
- Contact:
it is indeedy! will go off to the how too's!! thank you!
'58 C2 Code
'58 C2 Code
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
another estate I bet
We did mine earlier this year, remove wing, close door, release demon mig welder.
i would clean it up bridge weld, then plate across as well
Regards, malcolm.
