Tuning box HDI 110 C5
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
all, brought a tuning box from someone on here(was in for sale section)
Have a longish journey over weekend, would be good to fit it before I go..
where should I stick it? :mrgreen:
The is jsut a 3 pin male and seperate female connector - just need to know where to put them..
seems there is a plug going into the fuel rail , underneath it.. could this be the place..
would be bad to disable the car by getting it wrong..
John
x 1488
Re: Tuning box HDI 110 C5
I think that's the one John - the box just modulates the signal for the rail pressure to the ECU - this gives a higher rail pressure and therfore more fuel for a set opening time = bigger bang and more go. I sure read about Paul doing it - releasing the connector was not to hard, putting it back, on the other hand :twisted:
jgra1
(Donor 2021)
x 36
hehe thanks Richard..
will throw it on later and report back...
device has 10 settings, and another button which is green / red toggle..
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
I have a box on my HDi, however, its NOT a rail pressure fooling device. Not sure which is the best sort.
The box I have connects to the battery + and - terminals, and theres a harness that then connects inbetween the cars injector plugs and corresponding injector plug. A little like an LPG sequentail harness on an injected car.
Its been on for 90k now and had no issues at all ..
Can you post a good pic or two of your box John, might help diagnose connection. The connection to the fuel rail sensor which is the sonsor pointing downwards, should be three Pin..
A very sad...
1994 XM 2.1 d auto
jgra1
(Donor 2021)
x 36
fitted ., what a pig getting the 3 pin back in.. headtorch and dark.. but took 20 mins to throw it on..
will tidy tomorrow#
set on 10, and with the light set to green not red, it is a noticeable difference.. especially from 1500 -2500.. get a real kick in top 4 gears.. 1st serves no purpose anymore really... not that I ever used it much
will see what economy it does on a run to Dorset tomorrow
addo
Sara Watson's Stalker
x 95
Unread post by addo »
How's its fuel habit now?
jgra1
(Donor 2021)
x 36
last night , 2.5 hours constant motorway at up to 90mph.. 3 adults and dog and boot full.. 47.1mpg,, which seems the same as always :)
