noise when pressing clutch
davies2005
- New User
I have a picasso 1.6 petrol 52 plate and when i press or depress the clutch it makes a noise ive got shards of metal inbet ween the engine and gear box i can select all gears still just a noise when press or depress clutch any ideas
Skull
- (Donor 2026)
- x 380
Re: noise when pressing clutch
Could be your clutch release bearing starting to sieze by the symptoms you describe
Gary
Gary
- x 1488
Or the release bearing is chewing through the pressure plate. Either way, it is box out time....
- x 8389
And very much sooner rather than later...RichardW wrote:Either way, it is box out time....
davies2005
- New User
I did think it might need new clutch but didnt want pull everything out first just incase so wanted know what other thought first thanks for your response it looks like i am going to be busy.
flying clutchman
- x 3
you'll probably need the bearing support tube as well, they get chewed up usually. (cheap from ECP)
